thranduil
Member level 1
Hi all guys,
I am currently working on a simple radio communication simulator. The main idea is to calculate PER based on BER based on SNIR. At the moment I don't really like to be able to receive a lot of frame with power of arround -120 dBm (@434MHz) which sounds kind of unrealistic to me. SNIR ratio that I obtain is actually the value which is present at the antenna of the receiver and noise figures of the elements down the chain is still missing. In order to improve this an idea came to my mind. I have found in the datasheet of CC1000 receiver from Ti that sensitivity for BER=0.001 @ 19.2 kbits, frequency separation for fsk of 64 kHz, is -104 dBm. I wonder now how can I extrapolate this data in order to be able to estimate bit error rate for any given input power?
Thank you very much for you suggestions
