Using 4 oz copper means our SMD resistors & caps will not be soldered properly?
T
treez
Hello,
We are doing a 3 channel, surface mount Buck LED driver (3x 165W) , which is 495W total. The room on the PCB for this is just 60mm x 70mm.
So as to keep the components cool, we wish to use 4 oz copper…but will this mean that 0603 resistors will not be soldered properly? (there are 0603 resistors and caps near the PWM controller).
Re: Using 4 oz copper means our SMD resistors & caps will not be soldered properly?
Nope, as long as the board is profiled correctly for the reflow oven there should be no problems.
Reactions: treez
    T
