[Moved]Xilinx Vivado compiler problem or systemverilog declaration error
dpaul
Germany
Hi all,
I am trying to simulate a uP core defined in sv using Xilinx Vivado suite.
However I get an error message for which I cannot find a fault.
Error: "[VRFC 10-301] an enum variable may only be assigned to same enum typed variable or one of its values"
This error message points to the part of the code as below:
`ifdef MPU_EN
    output  logic   [ ARCHITECTURE_BASE-1:0]      dmem_rd_check_addr,
    output  type_operation_mode_e                           dmem_rd_check_size,  <-- ERROR line
`endif
Note that in the above error line, the variable 'dmem_rd_check_size' is allocated to type 'type_operation_mode_e'.
I have the 'type_operation_mode_e' defined in an `include file as follows:
typedef enum logic [1:0] {
    DATA_MODE_BYTE,
    DATA_MODE_WORD,
    DATA_MODE_DWORD,
    DATA_MODE_X=2'bxx
} type_operation_mode_e;
I have checked this entire file/code and no where is there an illegal assignment for 'dmem_rd_check_size'.
Then why is the Vivado simulator throwing such an error?
I have hit a wall. Please help or advice.
