HINDI
Member level 3
- Joined
- May 1, 2004
- Messages
- 56
- Helped
- 2
- Reputation
- 4
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- MISR "EGYPT"
- Activity points
- 622
mosfet gate driver circuit
The MOSFET gate drivers are used to ensure a complete on/off state for mosfets .
Also, if the MOSFET is a high side switch the source will be considered as a floating point while it is not tied to the ground , so it is important to ensure that the voltage Between the gate and the source is more than 12 v to avoid the negative temperature coefficient region .
In the IR2110 i can't understand how the under voltage block will be triggered if the voltage between the source and the gate is less than 10v .
see the attachment plz .[/img]
