+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Newbie level 1
    Points: 15, Level: 1
    Join Date
    Sep 2013
    Posts
    Points
    15
    Level
    frequency measurement device???
    can i know how do i convert ferquency of rotor of a m/c into binary form so dat i can use dat data for some other purpose???
    •   Alt16th September 2013, 18:32
      advertising
  2. #2
    Super Moderator
    Points: 239,598, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    Re: frequency measurement device???
    "rotor of a m/c" means what?
    •   Alt16th September 2013, 19:00
      advertising
  3. #3
    Full Member level 2
    Points: 1,400, Level: 8
    Join Date
    Aug 2013
    the Netherlands
    Posts
    120
    Points
    1,400
    Level
    8
    I think he wants to make a digital rpm meter for a motor-cycle.
    Usama, if you want usable answers, then it helps to give more and clear information and skip the use of abriviations.Now we have to guess what you want.
    •   Alt16th September 2013, 23:22
      advertising
  4. #4
    Member level 4
    Points: 1,618, Level: 9
    electroM's Avatar
    Join Date
    Jul 2013
    Pune, INDIA
    Posts
    72
    Points
    1,618
    Level
    9
    opto coupler may be helpful.
  5. #5
    Points: 7,332, Level: 20
    Venkadesh_M's Avatar
    Join Date
    Jun 2013
    Coimbatore, India
    Posts
    1,375
    Points
    7,332
    Level
    20
    there are lot type of speed sensors like you can simply connect a small dynamo and using ADC you can give it to the controller....
  6. #6
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    May be. I had considered this meaning if a motorcycle had a "rotor". Of course it has many rotating parts, e.g. wheels or a crank shaft, but not particularly a "rotor".
    1 members found this post helpful.
    •   Alt17th September 2013, 09:07
      advertising
  7. #7
    Full Member level 5
    Points: 2,598, Level: 11
    Magvitron's Avatar
    Join Date
    Aug 2012
    Kollam (Quilon), India, India
    Posts
    241
    Points
    2,598
    Level
    11
    Blog Entries
    Hi you can do it with
    1. Optical interrupt counter
    2. Hall effect sensors
    etc.
    Or you can brain storm one! ;)
    The occasional visit of success provides just the excitement an engineer needs to face work the following day.
    Koichi Tanaka
  8. #8
    Full Member level 2
    Join Date
    Aug 2013
    the Netherlands
    Posts
    120
    Points
    1,400
    Level
    8
    It can be a language thing, something that rotates is a rotor and maybe he does not know the right name. (rotor is shorter as crankshaftflywheel, and he seems to like short words.
    But serious, my 54' Triumph speedtwin has a rotor in the ignition,
    But we will hopefully hear what he wants to build.
