+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Full Member level 2
    Points: 3,186, Level: 13
    Join Date
    Dec 2003
    Posts
    135
    Points
    3,186
    Level
    13
    negative resistor
    In the analog filter design. Sometimes we need a negative resistor. Then how to build a nagative resistor? Use feedback? how?
    •   Alt23rd December 2004, 22:27
      advertising
  2. #2
    Points: 10,418, Level: 24
    Join Date
    Sep 2001
    Argentina
    Posts
    1,131
    Points
    10,418
    Level
    24
    How to build a negative resistor??
    Hi Alles,
    You can use a Negative Inmitance Converter (NIC). Look for it in network theory literature. It is an active device with one operational amplifier and 2 resistors that converts an impedance Z (not necessarily resistive) into -k*Z. It uses feedback, of course.
    Regards
    Z
    (with a NIC I become -Z, ha...)
    1 members found this post helpful.
  3. #3
    Full Member level 2
    Points: 2,543, Level: 11
    Join Date
    Oct 2004
    Posts
    143
    Points
    2,543
    Level
    11
    i think if u realize the filter in sc mode then sc inverting connected circuit acting as a negtive res should be used
    •   Alt23rd December 2004, 23:27
      advertising
  4. #4
    v_naren
    Re: How to build a negative resistor??
    there u go
  5. #5
    Full Member level 3
    Points: 2,849, Level: 12
    Join Date
    Aug 2004
    Posts
    186
    Points
    2,849
    Level
    12
    I did not know that you can build negative resistance with MOSFETs. probably thats the best answer.
    - this is what i got:
    Usually, my way has been to have an OpAmp, with its inverting node connected to both the output node of the OpAmp (feedback resistance R3) and the input current (Iin) and the non-inverting node is connected to both the output node of the OpAmp through R2 resistor and to the ground via R1 resistor. the Output is given by:
    Vout = -R3*R1*Iin/R2.
    Vout is between the inverting node and the ground.
    •   Alt2nd January 2005, 00:37
      advertising
  6. #6
    Join Date
    Sep 2001
    Argentina
    Posts
    1,131
    Points
    10,418
    Level
    24
    What srivatsan described is a NIC.
    For any Z1 in the place of R1:
    Zin=-(R3/R2)*Z1
    -Z
  7. #7
    v_naren
    well since the question is for a negative resistor I think the cross-coupled mos pair is simple enough.
