+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Junior Member level 1
    Points: 527, Level: 4
    Join Date
    Apr 2013
    Ahmedabad, India, India
    Posts
    18
    Points
    527
    Level
    static timing analysis
    there are two type of static timing analysis. pre STA and post STA. so ,how do this using sysnopsys tool?
  2. #2
    Points: 8,808, Level: 22
    Achievements:
    7 years registered
    Join Date
    May 2010
    Marin
    Posts
    1,481
    Points
    8,808
    Level
    22
    Re: static timing analysis
    STA means static timing analysis, then you could analyze your design at any time of the flow. Generally the STA is only done as final step to check everything is fine.
    •   Alt15th April 2013, 19:17
      advertising
  3. #3
    Advanced Member level 1
    Points: 3,888, Level: 14
    Join Date
    Oct 2010
    Ahmedabad,INDIA
    Posts
    492
    Points
    3,888
    Level
    14
    Blog Entries
    Pre STA is done by Design Compiler and is done before PnR..
    and Post STA is done by Prime Time and is done on Post layout netlist....
    But I can't understand that how we can do Pre STA as there is not any interconnection wire length information.
    •   Alt16th April 2013, 04:35
      advertising
  4. #4
    Member level 5
    Points: 1,288, Level: 8
    Join Date
    Dec 2010
    Taipei, Taiwan
    Posts
    84
    Points
    Level
    8
    Quote Originally Posted by maulin sheth View Post
    Therefore, the timing analysis will be more accurate after post STA.
    But we will try to estimate the interconnection delay before layout stage, said topographical mode in Design Compiler.
    This will reduce the gap between the pre STA and post STA.
    •   Alt16th April 2013, 04:45
      advertising
  5. #5
    Full Member level 4
    Points: 2,385, Level: 11
    Join Date
    Jun 2010
    Bangalore
    Posts
    237
    Points
    2,385
    Level
    11
    Wireload and interconnect are modelled in pre layout stage and .libs are used to compute the timing. Post layout the actual RC values are taken into account for accurate analysis.
  6. #6
    Join Date
    Apr 2013
    Posts
    18
    Points
    527
    Level
    [QUOTE=jeevan.life;1222506]Wireload and interconnect are modelled in pre layout stage and .libs are used to compute the timing. Post layout the actual RC values are taken into account for accurate analysis.[/QUOTE
    what is the format for wire load model?as u said that it can be found in .lib file.so, will you please tell that how wire load model looks like?
    please gave me example.
  7. #7
    Join Date
    Oct 2010
    Ahmedabad,INDIA
    Posts
    492
    Points
    3,888
    Level
    14
    Blog Entries
    Wire load is a library file...and the format is .lib and also .db.... and .lib is ASCII format and .db is Binary format...
    It will include the wire load model...which contain the unit capacitance, fanout length etc....
    •   Alt16th April 2013, 13:25
      advertising
  8. #8
    Join Date
    Apr 2013
    Posts
    18
    Points
    527
    Level
    will please explain how wire load model look like? i have seen .lib file but i unable to find this wlm.
  9. #9
    Member level 5
    Points: 1,144, Level: 7
    Join Date
    Jun 2011
    Posts
    88
    Points
    1,144
    Level
    7
    You can use "report_lib lib_name " command in dc_shell. It should report wire load model too.
    1 members found this post helpful.
