Capacitor values for use with 32.768KHz crystal (microcontroller crystal)
T
treez
Hello,
I am using the ABS25-32.768KHz crystal with a microcontroller. Do you know what is the capacitance value that i have to use with it?...
The datasheet appears to recomend 1.35pF.....surely it can't be that low?
ABS25-32.768KHz crystal datasheet:
https://www.abracon.com/Resonators/abs25.pdf
The PIC datasheet does provide guidelines for selecting the capacitance:
But it does also mention this:
Pay attention to point 2.
So you might want to go with the recommended value.
Hope this helps.
Tahmid.
Reactions: treez
    T
