+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Points: 326, Level: 3
    Join Date
    Jun 2011
    Sri Lanka
    Posts
    Points
    326
    Level
    Problem with 230v LED Driver circuit
    I have been trying to make an AC LED lamp consisting of 44 LEDs. The LEDs are rectangular and give out a bright white light. I am not sure of the current of the LEDs and so have been trying different driver circuits to drive the LEDs. I tried the following circuit but the LEDs were dim. Can someone tell me what's wrong with the circuit?
    Click image for larger version.
    •   Alt21st October 2012, 10:51
      advertising
  2. #2
    Advanced Member level 2
    Points: 3,328, Level: 13
    Genovator's Avatar
    Join Date
    Dec 2011
    India
    Posts
    546
    Points
    3,328
    Level
    13
    Blog Entries
    Re: Problem with 230v LED Driver circuit
    It seems your current is too low. Replace the 220nF capacitor and place a 1uF one. You may require to add another capacitor in parallel if the light intensity is not desirable.
    Wading all day.....
    1 members found this post helpful.
    •   Alt21st October 2012, 12:12
      advertising
  3. #3
    Advanced Member level 5
    Points: 13,542, Level: 27
    nandhu015's Avatar
    Join Date
    Feb 2006
    India
    Posts
    1,960
    Points
    13,542
    Level
    27
    Blog Entries
    18
    What is the rated voltage of the LED's?
    •   Alt22nd October 2012, 03:46
      advertising
  4. #4
    Super Moderator
    Points: 46,805, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,668
    Points
    46,805
    Level
    52
    The bright whites that I'm familiar with are rated 3.6V at 20 mA.
    It's a good idea to include a resistor to limit inrush current on power-up. 330 ohms should be sufficient. 1W rating.
    I've made a simulation showing how you could drive these from 230V mains AC.
    The smoothing capacitor will acquire upwards of 180 V and must be rated higher than that. Its value is not critical.
    A 470 nF dropping cap appears sufficient to obtain 18 mA through the led's.
    If you are certain they can tolerate 25 mA, then try a 680 nF.
    Or a 1 uF if they are they kind that can tolerate 36 mA. Then the inrush resistor is carrying 3W peak.
  5. #5
    Newbie level 1
    Points: 750, Level: 5
    Join Date
    Feb 2010
    INDIA
    Posts
    Points
    750
    Level
    Thx its helpfull working...
    •   Alt23rd March 2014, 13:52
      advertising
  6. #6
    Newbie level 3
    Points: 847, Level: 6
    Join Date
    Oct 2010
    Punjab
    Posts
    Points
    847
    Level
    Thanksssssssssssssssssss
