+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Junior Member level 3
    Points: 1,572, Level: 9
    Join Date
    Nov 2004
    Posts
    29
    Points
    1,572
    Level
    9
    pwm circuit schematic
    Dear all:
    I would like to design a pulse width modulation circuit so that my circuit
    will have the different duty cycle ( 50%-50%, 40%-60%, 30%-70%).
    But I don't want to use the dividers to implement it, because it will decrease my output frequency. Anyone has other suggestion?
  2. #2
    Full Member level 3
    Points: 2,103, Level: 10
    Join Date
    Oct 2004
    Posts
    174
    Points
    2,103
    Level
    10
    cmos pwm comparator
    did you design a IC PWM or use IC to realise?
    •   Alt4th November 2004, 11:19
      advertising
  3. #3
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    how to design a pwm
    First of all you need a clock circuit which you can build using to 2 CMOS NAND gates ar 555. Secondly, you need a circuit that will be trigged by this clock and will have ability of changing width of pulses. This can be realised with CMOS CD4528 but instead of connecting only resistor in its RC tank you will connect this resistor through C-MOS switch (eg CD4066). You can use as many switches with different resistors as you wish. Each combination will give you different pulse width.
    Alternatively you can use P-MOSFET transistor as variable resistor or digital potentiometers IC (eg Dallas DS1804-50, 50k, 100 steps) to control the value of R.
    There are thousands way of doing this, it is just the matter of your imagination....
    Other thing is how would you like to control the width of pulses?
    1 members found this post helpful.
    •   Alt5th November 2004, 01:55
      advertising
  4. #4
    Full Member level 5
    Points: 2,541, Level: 11
    Join Date
    Oct 2004
    Posts
    307
    Points
    2,541
    Level
    11
    comparator cmos circuit
    use 555 to generate slope,a high gain opamp as error amp.& power mos as the output stage.
    •   Alt5th November 2004, 06:07
      advertising
  5. #5
    Junior Member level 2
    Points: 1,551, Level: 9
    Join Date
    Dec 2004
    Posts
    22
    Points
    1,551
    Level
    9
    cmos pwm circuit design
    PWM circuit you can make with simple CMOS comparator that compare from one side sinewave voltage and other side is triangular voltage.
  6. #6
    Member level 3
    Points: 2,112, Level: 10
    Join Date
    Jan 2005
    Posts
    59
    Points
    2,112
    Level
    10
    pwm cmos circuit
    Try TL494
  7. #7
    Points: 1,739, Level: 9
    Join Date
    Aug 2003
    Posts
    28
    Points
    1,739
    Level
    9
    pwm with cd4528
    anyone has the PWM schematic or reference manual ?
    •   Alt3rd February 2005, 09:40
      advertising
  8. #8
    Junior Member level 1
    Points: 1,167, Level: 7
    Join Date
    Nov 2006
    Posts
    17
    Points
    1,167
    Level
    7
    pwm circuit
    this is a good paper
  9. #9
    Full Member level 1
    Points: 1,931, Level: 10
    Join Date
    Nov 2004
    Posts
    118
    Points
    1,931
    Level
    10
    Re: How to design a PWM circuit in CMOS circuit?
    Are you talking about duty cycle corrector or PWM? From your statement, I think is duty cycle corrector.
    PWM is including ramp generator, comparator etc.
    Duty cycle corrector is capacitor plus some other ckt.
