+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Full Member level 5
    Points: 1,942, Level: 10
    Join Date
    Apr 2012
    bangalore
    Posts
    311
    Points
    1,942
    Level
    10
    how to convert decimal to hexdecimal in assembly
    can anyone help me
    •   Alt13th April 2012, 18:15
      advertising
  2. #2
    Advanced Member level 5
    Points: 11,741, Level: 25
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    1,800
    Points
    11,741
    Level
    25
    Re: how to convert decimal to hexdecimal in assembly
    write a decimal to binary conversion routine and transform the resultant binary to hexadecimal.
    you have not specified it for which controller . remember assembly code differs for each controller
    •   Alt13th April 2012, 18:29
      advertising
  3. #3
    Points: 20,490, Level: 34
    Achievements:
    7 years registered
    Join Date
    May 2009
    Prime Meridian
    Posts
    3,056
    Points
    20,490
    Level
    34
    Quote Originally Posted by jjeevan007 View Post
    can anyone help me
    I think this is what you mean ..
    In Pic Assembler you simply tell it what the value is Decimal, Hex, Binary. example :-
    movlw d '255'
    movlw 0xFF
    movlw b'11111111'
    If when writing your code you want to use nearly all decimal values , in MPlab for instance ,you can set the default Radix to Decimal so all the complier assumes all values are decimal unless otherwise prefixed.
    Its when you come to output the values to say an lcd that you then need some code to convert it to Ascii etc.
    •   Alt13th April 2012, 23:47
      advertising
  4. #4
    Full Member level 2
    Points: 984, Level: 7
    Join Date
    Mar 2012
    Posts
    133
    Points
    984
    Level
    7
    I've done it using a table... It was quite long time ago, I cannot remember exactly how I did, but I think I setup a ROM in assembly which has decimal input and hex output.
  5. #5
    Full Member level 5
    Join Date
    Apr 2012
    bangalore
    Posts
    311
    Points
    1,942
    Level
    10
    Re: how to convert decimal to hexdecimal in assembly for 8051
    Quote Originally Posted by srizbf View Post
    for 8051 controller
    eg: the contains of accumulator is 99 then it has to be converted to 63
    •   Alt16th April 2012, 07:23
      advertising
  6. #6
    Full Member level 3
    Points: 1,485, Level: 8
    Arch Zone's Avatar
    Join Date
    Dec 2011
    Daerah Khusus Ibukota Jakarta, Indonesia
    Posts
    171
    Points
    1,485
    Level
    8
    Try this (Source and result at accumulator):
    [syntax=asm]
    Begin:
    Mov A,#99h
    Acall Con_Dec_2_Hex
    Sjmp $
    Con_Dec_2_Hex:
    Push Acc
    Anl A,#F0h
    Swap A
    Mov B,#0Ah
    Mul AB
    Xch A,B
    Pop Acc
    Anl A,#0Fh
    Add A,B
    Ret
    [/syntax]
    1 members found this post helpful.
  7. #7
    Full Member level 5
    Join Date
    Apr 2012
    bangalore
    Posts
    311
    Points
    1,942
    Level
    10
    Quote Originally Posted by Arch Zone View Post
    [syntax=asm]
    Begin:
    Mov A,#99h
    Acall Con_Dec_2_Hex
    Sjmp $
    Con_Dec_2_Hex:
    Push Acc
    Anl A,#F0h
    Swap A
    Mov B,#0Ah
    Mul AB
    Xch A,B
    Pop Acc
    Anl A,#0Fh
    Add A,B
    Ret
    [/syntax]
    thank you very much
    it was help full
