Iman_b
Newbie level 3
- Joined
- Aug 25, 2010
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Melbourne,Au
- Activity points
- 1,303
hi
I simulated a structure with a solution frequency 915 MHz, which was desired frequency.
I repeated simulations with solution frequencies 2 GHz and 2.5 GHz.
Their S11 results were different from each other. The resonant frequency shifted each time to right hand side of x-axis.
So What should I set the solution frequency in order to achieve correct resonant frequency ? Should it be The desired frequency or end of the frequency range I use in my sweep ? if it should be end of the range, so how can I get the radiation pattern for my desired freq which is 915 Mhz ( since radiation pattern are illustrated for solution frequency)
Solution type is Driven Modal
My blessing to anyone who can help me, or at least tries to ...
Regards
Iman
Regards
Iman
