mr_l
Newbie level 5
Hello!
I'm trying to write code to control two servo with two potentiometers
Devices that I use is: microcontoller atmega88, breadboard, two servo Futaba S3003 and Elsy AVRUSB500 programmers.
Everything is properly connected but my code is not working as it should.
What happens when I try to control the servo is that only one potentiometer controls both servos.
Can someone tell me what is wrong in my code and how to solve this problem??
Thanks in advance here is my cod:
#include<avr/io.h>
#include<util/delay.h>
#include<avr/interrupt.h>
void ADC_init(void);
void Tim_init(void);
unsigned int ADC_read(unsigned char);
int main(void)
Tim_init(); // Initialization of Timer1
DDRB |= 0b00000111;// Set PB1 and PB2 as outputs
TCCR1A |= (1<<COM1A1); // PWM on port B1 - non-inverted compare mode 2
TCCR1A |= (1<<COM1B1); // PWM on port B2 - non-inverted compare mode 2
TCNT1 = 0;
OCR1A = 1500;
OCR1B = 1500;
TIMSK1 |= (1<<OCIE1A);
TIMSK1 |= (1<<OCIE1B);
ADC_init(); // Initialization of ADC
while (1)
if (TIFR1 & (1 << OCF1A))
OCR1A = ADC_read(0);
if (TIFR1 & (1 << OCF1B))
OCR1B = ADC_read(1);
void Tim_init(void)
TCCR1A = 0; // disable all PWM on Timer1
ICR1 = 19999; // frequency 20ms
TCCR1A = (1<<WGM11); // Timer 1 for Fast PWM mode via ICR1, with no prescaling
TCCR1B = (1<<WGM13) | (1<<WGM12) | (1 << CS10) ;
void ADC_init(void) // Initialization of ADC
ADMUX=(1<<REFS0); // AVcc with external capacitor AREF
ADCSRA=(1<<ADEN)|(1<<ADPS2)|(0<<ADPS1)|(0<<ADPS0); // Enable ADC and set Prescaler division factor as 128
unsigned int ADC_read(unsigned char ch)
ch= ch & 0b00000011; // Set chanel 1 or 2
ADMUX |= ch; // selecting channel
ADCSRA|=(1<<ADSC); // start conversion
while(!(ADCSRA & (1<<ADIF))); // waiting for ADIF, conversion complete
ADCSRA|=(1<<ADIF); // clearing of ADIF
return ((ADCL|(ADCH<<8))*8);
