cnhoff23
Newbie level 1
Hello,
i want to design a PIN diode switch control driver board with Opamps.
The prerequisites are:
- V+ 3V; V- -4V
- I+- 10mA
- cap load drive ~1500pF but behind a 30Ohm output series resistor
As my opamps will only swing from one rail to the other (setup as non-inverting amps; according to TTL input 0 or 3.3V they should either source 10mA from positive rail or sink -10 mA from neg. rail), a precise rail-to-tail amp that can reach the rails at these currents should be chosen.
But rail-to-rail amps are mostly single-supply. Can i have asymmetric V+ and V- or does V- have to be GND with a single supply amp?
Thanks
Chris
- V+ 3V; V- -4V
- I+- 10mA
Thanks
Chris
