Problem in Importing netlist from capture to pcb editor
varaprasad
Iam using orcad 16.0 version.I obtain the following session log error when i tried to create netlist from Orcad Capture to be used by PCB Editor for layout.I can able to get netlist files but it can't update in PCB editor.I getting following netlist files.
1) pstxnet.dat
2) pstxprt.dat
3) pstxchip.dat
Iam attaching session log what i get during importing netlist from capture to PCB editor.
Pls help me to slove this problem.
  • Session Log.txt
seems your problem is with IC MCP4822.
1. You are using footprint TSOP-8 for the same but the symbol (or footprint) has 14 pins.
2. second thing .PSM file for 'SOT23-5' is not available in your mapped libraries.
By correcting above errors you may successfully load the netlist to Allegro (PCB editor)
