aduri
Hello everyone,
my goal is to sample 2 sine (only positive) pulse signals (Va, and Vk) 70 times each in 10 msec to 7 times as the negative grid voltages.
The start is controlled by a polling on rb0.
I did the same thing with a PIC16F877A, without the fast adc function but with adc mikroBasic library, but it worked too slowly.
With the PIC18F4550 and the attached code sends all zeros in the serial yperterminal.
USART of the 4550 works differently from the 877A?
Help me please.
Best regards
Antonio
Help me please.
Best regards
Antonio
program prova_da_adc_232_4550
'in prova_da_adc_232
dim t as word
Text as char[20]
tword as string[5]
i as byte
dim Va as word[7][70] 'bidim. array for anodic voltage
dim Vk as word[7][70] 'bidim. array for anodic voltage
dim Ca,g,ch as byte 'Ca ---> sampling, g----> grid voltage
'function speed adc
sub function ReadADC(dim Ch as Byte) as word
ADCON2 = %10001010 ' FOSC/32 , 2 TAD ,Right Justified
ADCON0 = Ch * 4
SetBit(ADCON0,ADON)
SetBit(ADCON0,GO)
while TestBit(ADCON0,GO) wend 'Wait for Conversion
Result = ADRESH * 256 + ADRESL '10 Bit Right Justified
ClearBit(ADCON0,ADON)
end sub
sub procedure Usart_out
Usart_Init(9600)
for g=0 to 6
for Ca=0 to 69
t=Va[g][Ca] 'load array V anodic and k index Vgrid
wordtostr(t,tword)
Usart_Write_text(tword)
Usart_Write(",")
t=VK[g][Ca] 'load array V catodic and k index Vgrid
wordtostr(t,tword)
Usart_Write(";")
next Ca
next g
end sub
sub procedure setup
lcd_cmd(LCD_CLEAR)
lcd_out(1,1,"wait")
lcd_chr(2,9,"S")
lcd_chr(2,10,"T")
lcd_Out(2,11,"ART")
delay_ms(1000)
end sub
main:
TRISC=0x00
PORTB =0
TRISB =0
intcon =0
Lcd_init(PORTD)
lcd_cmd(LCD_CURSOR_OFF)
lcd_cmd(LCD_CLEAR)
'Text ="Tube tracer"
lcd_out(1,1,"Tube tracer")
Text ="A. Durighello"
lcd_out(2,1, Text)
'Setbit(PORTB,1) 'for usb project
OPTION_REG = $80
ADCON1 = $82
TRISA = $FF
Delay_ms(1000)
lcd_cmd(LCD_CLEAR)
Text = "Ciclo letture:"
Delay_ms(2000)
lcd_out(2,1,Text)
setup
while true
if (portb. 0 = 1) then
for g=0 to 6 'nr. 7 measure x each Vgrid
for Ca=0 to 69 '70 campioni per ogni tensione
'Va[g][Ca]=Adc_Read(0) 'load array V anodic and k index Vgrid
'Vk[g][Ca]=Adc_Read(1) 'load array V catodic and k index Vgrid
'adc con registri x 18f4550
Va[g][Ca]=ReadADC(0)
Vk[g][Ca]=ReadADC(1)
delay_us(3) 'to modify to target a delay about 10msec
next Ca
'g=g+1 ' shynchron.
next g
if (g = 6) then
usart_out
end if
end if
wend
end.
