CADENCE 5 simulation Warnig: object selected is not a valid object
nulll
Newbie level 5
Hi, I did the PA load-pull simulation(PSS) with cadence ic 5.
After simulation finished, I click the ADE as :Results—Direct Plot—Main Form. an form pop-up and told me "Select Instance Terminal on schematic".
So I cliked the terminal on schematic, But no reult form pop-up, and the CIW shows that Warnig: object selected is not a valid object.
did anyone see this problem before? Can anyone tell me how to solve this problem?
Thank you!
Do you mean the "Output plot/save" in the ADE?
I had seleted the "save" option for the terminal.
