+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Newbie level 1
    Points: 448, Level: 4
    Join Date
    Jun 2010
    Posts
    Points
    448
    Level
    JK Flip flop asynchronous counter
    Does anybody know how to build an asynchronous counter that counts from 2 to 9 with JK Flip Flops?
    Appreciate any advice.
    •   Alt12th June 2010, 04:54
      advertising
  2. #2
    Full Member level 2
    Points: 2,786, Level: 12
    Achievements:
    7 years registered
    Join Date
    May 2008
    KERALA
    Posts
    128
    Points
    2,786
    Level
    12
    Re: JK Flip flop asynchronous counter
    Hi quietfoot,
    You have to use 4 JK flip-flops, with asynchronous set and clear. Wire the JK FFs as T FFs by connecting J & K pins to a logic high. Connect the Q output of first FF to the CLOCK input of next FF and so on.
    Next you need a combinational logic which upon detecting a '1010' (decimal 10) on output clears FFs 1,3,and 4 (through the asynchronous clear pins) and presets FF 2 (through the asynchronous set pin).
    •   Alt12th June 2010, 08:51
      advertising
  3. #3
    Junior Member level 3
    Points: 903, Level: 6
    Join Date
    Jun 2010
    Irvine
    Posts
    28
    Points
    903
    Level
    @matbob
    Solution looks perfect, but we need to detect 1001 (Decimal 9) and set/clear the flops asynchronously.[/quote]
    •   Alt23rd June 2010, 18:08
      advertising
  4. #4
    Newbie level 3
    Points: 537, Level: 4
    Join Date
    Jun 2010
    solar system
    Posts
    Points
    537
    Level
    Dear freind
    for this purpose you have to make a table of what number it shows now and what number it should show with the next lock.since you want your counter to count 2 to 9 you can either 1-use 3 flip flip and design a decoder which convert number 0 to 7 to 2 to 9 or 2-use 4 flip flops.which I recommend the second choice.
    this way you can write like this:
    now / next clock
    0010 / 0011
    0011 / 0100
    to: 1001 / 0010
    after making this table you compare the similer bits in each row. and using the j_k flip flop trigger table you can decide how to use gates in input of these flip flops.
    as you see it is so easy.just it takes some time!
    Good luck!
  5. #5
    Points: 12,011, Level: 26
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    quietfoot,
    The approaches suggested by matbob and sheikhalipour will work. However, using the asynchronous set and clear inputs suggested by matbob has a potential problem: Suppose in going from states 0111 to 1000, th 2nd LSB bit (2^1) is slightly slower in switching than bits 2^0, 2^2 and 2^3. In this case, the counter would momentarily go to the state 1010, possibly causing a reset to state 0010. I t would be safer to decode state 1001, and use flip flops with synchronous set and clear inputs. This way any momentary false states would be ignored, since they would go away before the next clock pulse. This is the classic "Race" problem.
    Regards,
    Kral
