btbass
Advanced Member level 5
Here's a handy little reg file that allows you to Right Click a directory name and then it gives you the option of opening an admin command prompt in the directory.
Works with Win 7, 32-bit and 64-bit.
Unzip and double click to add the entries to the register.
You can right click the reg filename and select 'Edit' if you want to see what is does.
