+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Junior Member level 1
    Points: 685, Level: 5
    Join Date
    Mar 2010
    Posts
    16
    Points
    685
    Level
    interfacing i2c 3.3v device with a PIC of 5v
    Hello all
    my Microchip pic 16F877 uses 5V Vcc,
    and i need to interface it with my i2c ambient light sensor which use 3.3V Vcc.
    my questions are:
    1. Does the PIC and light sensor can commuincate or since they have differnte logic levels its not possible?
    2. what about the NXP PCA9512 levelshifter component ?
    can it do the job? does it work? do i need it?
    attached:
    NOA1302 light sensor.
    PIC16F877 Micro.
    NXP level shifter.
    Thanks,
    amico.
    attached
    •   Alt2nd March 2010, 13:53
      advertising
  2. #2
    Advanced Member level 2
    Points: 10,590, Level: 24
    M!k's Avatar
    Join Date
    Apr 2002
    Posts
    682
    Points
    10,590
    Level
    24
    Re: interfacing i2c 3.3v device with a PIC of 5v
    Please check the logic levels in the datasheet and you'll see that it doesn't work. So you'll need levelshifter.
    Btw. there's a nice application note from NXP/Philips about that using FETs only:
    http://ics.nxp.com/support/documents...df/an97055.pdf
    •   Alt2nd March 2010, 14:16
      advertising
  3. #3
    Join Date
    Mar 2010
    Posts
    16
    Points
    685
    Level
    Thanks for the answer.
    can I trust the NXP PCA9512 level shifter to do the job?
    does anyone have any experience with this component or can recommend another level shifter for my application?
    Thanks.
    •   Alt2nd March 2010, 14:21
      advertising
  4. #4
    Newbie level 1
    Points: 469, Level: 4
    Join Date
    Apr 2010
    Canary Islands
    Posts
    Points
    469
    Level
    Hi! I've just had got that problem in my final degree project, and I've applied that solution:
    http://www.neoteo.com/adaptador-de-n...2c-3-3v-5v.neo
    I'm using a IRF510S as mosfets, but you can use other one. It's working, and I can see the bus pulses in a oscilloscope:
    Good luck! :)
