How to use USART in mikroCwithout errors?
r3stles
Newbie level 3
hELP
I need help.
How to declare: USART in mikroC
The code id :
USART_INIT(9600); //initializare serial port
SPBRG=103; // Pentru 9600 baud rade
but I'm error : undeclared identifier USART_INIT in expression.
Re: hELP
Does your hardware has USART device?
Amr Ali
Re: hELP
I want to send data to serial port through HyperTerminal
Re: hELP
Does your ship has a USART port?
Amr Ali
Re: hELP
What do you mean you have port USART. I'm used to PIC16F877A and MAX232 for transmitting data
Re: hELP
Did you check the case of the function? C is case sensitive.
I think it is Usart_Init not USART_INIT.
Amr Ali
hELP
mikroC is not case sensitive.
Try
UART1_Init(9600);
You do not need to write SPBRG = 103, as the compiler does that for you when you init UART.
Hope this helps.
Tahmid.
Re: hELP
Do you mean that compiler supported functions are not case-sensitive?
Amr Ali
Added after 15 minutes:
Check that link for errors and supported functions in MikroC **broken link removed**
Amr Ali
