+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Member level 2
    Points: 1,092, Level: 7
    Join Date
    Jul 2008
    Posts
    51
    Points
    1,092
    Level
    7
    How to include header file in VHDL module
    Hi all,
    Could you tell me how to include a header (.h) file in VHDL.
    In verilog we does like this.
    entity X
    end entity;
    `include "rtl/def_HarrisCorner.h"
    How it will achieved in VHDL module. And where exactly it will be done the VHDL file.
    Any help is appreciated.
    Regards
    •   Alt6th February 2010, 16:06
      advertising
  2. #2
    Super Moderator
    Points: 239,598, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    Re: How to include header file in VHDL module
    There's no header file option in VHDL. To make project wide assignments of constants and define types or functions, you can use a package.
    All packages are compiled to the library work by default.
    package DEFS is
      CONSTANT MAJOR_VERSION: INTEGER := 0;
      CONSTANT MINOR_VERSION: INTEGER := 22;
      CONSTANT MAXREG: integer := 52;
      TYPE REGS_TYPE is array (0 to MAXREG) of STD_LOGIC_VECTOR(15 downto 0);
      FUNCTION opndrn(inp: std_logic) return std_logic;
    end package DEFS;
    package body DEFS is
    FUNCTION opndrn(inp: std_logic) return std_logic IS
     begin
        CASE INP is
          WHEN '0' => return '0';
          WHEN OTHERS => return 'Z';
        END CASE;
     end;
    end package body DEFS;
    to include the package in a compilation unit
    LIBRARY work;
    USE work.defs.all;
    As an interesting feature, the types defined in a package can be referenced in an entity port definition.
    1 members found this post helpful.
    •   Alt6th February 2010, 17:31
      advertising
  3. #3
    Member level 2
    Join Date
    Jul 2008
    Posts
    51
    Points
    1,092
    Level
    7
    Thanks for answer. Its working!
    Regards,
    •   Alt7th February 2010, 06:40
      advertising
  4. #4
    Member level 2
    Join Date
    Jul 2008
    Posts
    51
    Points
    1,092
    Level
    7
    Hi all,
    Thanks for your responses.
    Added after 1 hours 13 minutes:
    Hi all,
    If there are more no of constants in def file, can I keep them in seperate file and include. If so how???
    Anybody could help me.
    Regards
