difference between ATMEGA8-16PU and PIC16F877
calin17us
Junior Member level 1
atmega8-16pu
what are de difference between ATMEGA8-16PU and PIC16F877.....
PIC16F877
has:
-35 instruction (RISC arhitecture)
-Up to 8K x 14 words of FLASH Program Memory,
-Up to 368 x 8 bytes of Data Memory (RAM)
-Up to 256 x 8 bytes of EEPROM Data Memory
ATMEGA8-16PU
has:
-130 Powerful Instructions (RISC arhitecture)
-Up to 16 MIPS Throughput at 16 MHz
-512 Bytes EEPROM
-1K Byte Internal SRAM
i dont know what to use.....how is the best.....?
is easy to program pic or atmel?
suports AT commands?
plesse help me...
difference in atmega8-16pu and atmega8l
Microchip doesn't recommend the PIC16F877 for new designs - it has been superceded by the PIC16F887.
For someone to provide a valid recommendation, you need to provide details on your project. Otherwise, we can't accurately gauge the memory, power and speed requirements necessary to meet your needs. There are thousands of processor to choose from.
Microchip has a great on-line tool that can aid you in selecting a controller - https://www.microchip.com/maps/microcontroller.aspx
atmega vs pic16f
i take same information from 2,3 ore 4 sensors(temperature, weight, vibration, humidity) with a microcontrolor, and y have to send them to distance(with GSM modem) to a computer.
I want to use pic-ul but my teacher want to use atmel-ul...and i need to know what to use......
how to program atmega8-16pu
Are yuo programming in C or Assembly Language?
atmega8-16pu programer
Assembly Language
Added after 27 seconds:
Assembly Language i dont like C
Added after 3 minutes:
C seems to be hard to understand....thats the reason...i preffer assembly
