+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 1
    Points: 759, Level: 6
    Join Date
    Sep 2008
    Posts
    Points
    759
    Level
    555 signal generator
    hi, everybody..
    I want to build a function generator by using 555 timer for signal generator and it capable of outputting a square wave with adjustable frequency in the ranges of 1Hz to 100Hz..
    If anyone have an idea please let me know...thanks for your cooperation..:D
    •   Alt15th September 2008, 01:53
      advertising
  2. #2
    Full Member level 6
    Points: 3,633, Level: 14
    Join Date
    Jun 2004
    Sao Paulo - Brasil
    Posts
    332
    Points
    3,633
    Level
    14
    555 function generator
    You will not get a symmetric square wave with only the 555 (50% duty cycle) and a variable output frequency will change the duty cycle also. Try another IC like XR2206.
    •   Alt15th September 2008, 22:17
      advertising
  3. #3
    Full Member level 5
    Points: 3,185, Level: 13
    Join Date
    Feb 2007
    USA
    Posts
    260
    Points
    3,185
    Level
    13
    555 timer frequency generator
    Yo can connect a diode in parallel to the resistor between the pins 6 and 7 to achieve this.
    •   Alt16th September 2008, 00:19
      advertising
  4. #4
    Member level 4
    Points: 2,187, Level: 10
    Join Date
    Nov 2004
    Posts
    69
    Points
    2,187
    Level
    10
    555 timer function generator
    http://hmin.tripod.com/als/
    Look in the Timers and Counters Section.
    There are 555 examples, but the TL494 circuits are
    more capable of 50% duty cycles. Root around.
    <als>
