+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 25
  1. #1
    Points: 1,051, Level: 7
    Join Date
    Apr 2007
    Posts
    Points
    1,051
    Level
    7
    Question about the beta value in BJT
    hi all,
    I have a question about the beta value of Bipolar transistor.
    Is β a constant value ? If β changes, which factors cause it?
  2. #2
    Full Member level 1
    Points: 2,453, Level: 11
    Join Date
    Nov 2005
    Nairobi
    Posts
    114
    Points
    2,453
    Level
    11
    bipolar transistor beta
    Beta is a variable quantity within certain limits defined by the manufacturer's data sheet. It is affected by the currents flowing and junction temperature.
  3. #3
    Junior Member level 3
    Points: 1,172, Level: 7
    Join Date
    Jun 2008
    Posts
    28
    Points
    1,172
    Level
    7
    beta value for bjt
    beta of any transistor depends on the manufacturing material...along with the doping levels....the characteristic resistivity of the materials...the bandgap voltage....many factors....if u still want to know abt the beta dependence of transistor use any Basic Electronics book...it will be very useful..
    1 members found this post helpful.
    •   Alt26th June 2008, 12:38
      advertising
  4. #4
    Member level 4
    Points: 1,691, Level: 9
    rizwanspirit's Avatar
    Join Date
    Feb 2008
    Posts
    74
    Points
    1,691
    Level
    9
    2n3904 beta value
    in the data sheet of any bjt there are 2 β. Hfemin and Hfemax.i want to know that in our calculation which β is used.
  5. #5
    Join Date
    Jun 2008
    Posts
    28
    Points
    1,172
    Level
    7
    beta bjt
    in any calculation of the circuits....involving beta....the hfe should be taken as the avg value...as considering the loadline and the beta variation...a safe approach is to use the mid value.....this is what i have practised..
  6. #6
    Full Member level 6
    Points: 4,037, Level: 14
    TekUT's Avatar
    Join Date
    Jun 2008
    Italy
    Posts
    323
    Points
    4,037
    Level
    14
    bjt beta computation
    Quote Originally Posted by rizwanspirit
    If you're designing a circuit with power transitor that should be work on saturated state you have to consider the beta min to sure saturation in every condition.
    Cheers
    F.F. a.k.a. Powermos
  7. #7
    Advanced Member level 5
    Points: 48,446, Level: 53
    Achievements:
    7 years registered
    Audioguru's Avatar
    Join Date
    Jan 2008
    Toronto area of Canada
    Posts
    8,423
    Points
    48,446
    Level
    53
    beta in transistor depend on
    Beta is not used for a saturated transistor. The collector to emitter voltage for the beta spec is much higher than it is for a saturated transistor.
    The minimum beta for a 2N3904 transistor at 1ma and with a vce of 1.0V is 70. But its max saturation voltage of 0.2V is when its base voltage is much higher than 1/70th, it is 1/10th.
    The minimum beta for a 2N3055 power transistor is 5 at 10A and when its Vce is 4.0V. But its max saturation voltage of 3.0V at 10A is when its base current is much higher at 3.3A.
  8. #8
    Full Member level 6
    TekUT's Avatar
    Join Date
    Jun 2008
    Italy
    Posts
    323
    Points
    4,037
    Level
    14
    forced beta of bjts
    @Audioguru
    I've reported a consideration not a rule, Bmin has to be used when you have to sure to drive in saturation a power BJT (e.g. 2N3055) then in calculation of the driving stage this value is obviously conservative and grant the saturation condition in every working condition.
    Only this...
    Cheers
    •   Alt27th June 2008, 01:30
      advertising
  9. #9
    Achievements:
    7 years registered
    Audioguru's Avatar
    Join Date
    Jan 2008
    Posts
    8,423
    Points
    48,446
    Level
    53
    the used of beta for bjt
    The minimum beta is only used for a linear transistor, not one that is saturated. More base current is needed when a transistor is saturated.
    •   Alt27th June 2008, 01:36
      advertising
  10. #10
    Full Member level 6
    TekUT's Avatar
    Join Date
    Jun 2008
    Italy
    Posts
    323
    Points
    4,037
    Level
    14
    calculate saturated ic
    Yes I'm agee with you on this point, this the reason why to design such type of behaviour we usually said that beta forced of the transistor has to be less than minimum beta, this is exactly the same as you said, in fact this require more current into the base than the one that is with the minimum beta (linear and init of quasi saturation region). From this point of view, as a pratical rule, we design saturation in order to have a final forced beta which is less than the minimal value on datasheets. This was when I've started to design switching converter, and also when I've to fight in order to avoid the deep saturation with the Baker clamp way... after that with MOS is another story... :D
    Tnx for reply.
    Cheers
    Pow
  11. #11
    Full Member level 5
    Points: 2,454, Level: 11
    Join Date
    Apr 2007
    Philippines
    Posts
    271
    Points
    2,454
    Level
    11
    bjt transistor beta
    collector current is one.
  12. #12
    Member level 1
    Points: 1,223, Level: 7
    Join Date
    May 2007
    Posts
    40
    Points
    1,223
    Level
    7
    how to get beta from a bjt
    ...but there's a "Vce_sat vs Ic graph (at different temperature curves)" in the datasheet with condition hfe=20
    therefore, beta is still used in saturation region... the difference is, beta is small at saturation region compare to beta at active region (usually at 100~400)
  13. #13
    Achievements:
    7 years registered
    Audioguru's Avatar
    Join Date
    Jan 2008
    Posts
    8,423
    Points
    48,446
    Level
    53
    a in bjt
    hFE is not used when a transistor is saturated. Each transistor is different.
    Some transistors like the 2N3904 and 2N4401 list their max saturation voltage loss when their collector current is 10 times the base current.
    Power transistors like the 2N3055 list their max saturation voltage loss when their collector current is 10A and their base current is 3.3A.
    Curves on datasheets usually show "typical". Maximum amd minimum values could be much worse.
  14. #14
    Member level 1
    Join Date
    May 2007
    Posts
    40
    Points
    1,223
    Level
    7
    beta value for transistor bjt
    ...but how could we calculate how much base current (Ib) needs to make sure that our transistor will fully saturate at a certain collector current (Ic)??
    ... In my case, I usually use the VCEsat vs Ic graph in the datasheet at a certain beta (Ic/Ib), mostly around 10-20... (example: Fig3 page7 http://www.nxp.com/acrobat_download/...C547_SER_7.pdf)...
    ...at a known collector current (Ic) and at beta (Ic/Ib)= 20 (based on the example graph), I can calculate the minimum required base current (Ib) that can surely fully saturate my transistor.. and so far, it always works for me. =)
  15. #15
    Achievements:
    7 years registered
    Audioguru's Avatar
    Join Date
    Jan 2008
    Posts
    8,423
    Points
    48,446
    Level
    53
    what is beta of bipolar transistor
    Where can you buy "typical " transistors? Sometimes they are not made perfectly and are with minimum specs.
    Maybe a radio manufacturer ordered all the low satutration ones before your order.
    I always design circuits to work perfectly if the transistors are minimum spec. Then ALL my projects work.
  16. #16
    Member level 1
    Join Date
    May 2007
    Posts
    40
    Points
    1,223
    Level
    7
    how to obtain beta of the bjt datasheet
    yeah right... we all know about that... "there's no such thing as ideal in this world"
    ...but my point is when designing a circuit from a scratch, how could we calculate how much base current (Ib) needs to make sure that our transistor will fully saturate at a certain collector current (Ic)??
    ... then, my approach is use the VCEsat vs Ic graph in the datasheet at a certain beta (Ic/Ib)...
    note: beta in saturation is different from the beta in active region.... in saturation, beta is small (around 10~20) and in active, beta is higher (around 100~400).....
  17. #17
    Achievements:
    7 years registered
    Audioguru's Avatar
    Join Date
    Jan 2008
    Posts
    8,423
    Points
    48,446
    Level
    53
    what is beta in bjt
    The graphs in a datasheet show a "typical" transistor. Many transistors are worse and have a much lower current gain and have a much higher saturation voltage which requires much more base current as shown in the text part of the datasheet.
    Maybe the range is wide because sometimes a semiconductor manufacturer has a poor yield that has many minimum transistors that they still want to sell.
  18. #18
    Member level 1
    Join Date
    May 2007
    Posts
    40
    Points
    1,223
    Level
    7
    veta cuanto vale en bjt
    ... and how could you calculate how much base current (Ib) needs to make sure that our transistor will fully saturate at a certain collector current (Ic)??
    "Trial and error???" I think this is not a good idea and will come up with a very poor design and takes a lot of time..
  19. #19
    Achievements:
    7 years registered
    Audioguru's Avatar
    Join Date
    Jan 2008
    Posts
    8,423
    Points
    48,446
    Level
    53
    ib and ic relation a bjt in saturation region
    You don't need "trial and error". The datasheet lists the minimum amount of base current for a transistor to saturate with a certain maximum voltage loss.
    Use the minimum and maximum guaranteed values on the datasheet then ALL your circuits will work, not just some of them.
  20. #20
    Member level 1
    Join Date
    May 2007
    Posts
    40
    Points
    1,223
    Level
    7
    beta > 100 for bjt
    Yes of course we can use the datasheet's minimum base current to saturate a transistor, provided that it's available... but some datasheets I encounter (most of them) has no such information.....
    take for example on the datasheet link I've provided before:
    •   Alt2nd February 2009, 10:51
      advertising
