Rob B
Full Member level 4
using coregen modules
I've been looking at this today and have found several work-flows but I'm still confused.
I need to do two things, the first of which is not critical as I could write a MicroBlaze software driver and bit-bang. Using a HDL module would be a bonus though, and may speed things up if I use interrupts. I think these things are essentially the same from the view of getting them to work with a MB and EDK.
1. Add a Verilog HDL module to the MB in the EDK.
2. Add a CoreGenerator module (a FFT core) to the MB in the EDK.
Do I have to put these into ISE and create a kind of port translation to interface them to the On-chip Peripheral Bus? Do I put both the modules into some new project in ISE with a top level that does the mapping?
Does anyone have any concise information on this topic please?
Regards,
Rob
Regards,
Rob
