microlab
Full Member level 5
cc2500
I am interfacing CC2500 with AT89C2051 to build a transmitter/receiver pair. Succeeded in writing and reading from and to registers within each module. But data transfer is not succeeding in the pair. Status LED on receiving side does not give any indication of reception.
On the transmission side, transmission buffer is overflowing and the LED status shows this . How do I test that the data transmitted has successfully been received at the other end ?
I have used the register setting as given in RF studio. Maybe something is missing in these settings. Can someone provide the settings which have worked at your end ?
ML
ML
