ardique
Junior Member level 2
cst studio suite 2008
hi,
i've design a circular patch microstrip antenna with narrow slot for 2.4GHz circularly polarization..the antenna that i design is right hand circular polarization and using coaxial feeding.. the Q is how do i know that my design is the correct one by using cst? what i need to determine is the radiation pattern, the s11 parameter < -10dB, the bandwidth = 200MHz, the VWSR <2 and the input impedance = 50ohm.. so far from my design i've get the s11 parameter, VSWR and the bandwidth only.. any advice:?:
hi,
