+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Full Member level 3
    Points: 2,826, Level: 12
    Join Date
    Jul 2006
    North Judson, IN USA
    Posts
    166
    Points
    2,826
    Level
    12
    rj12 pinout
    I am considering a design for a universal ZIF. The design would be usable with PIC, and possibly others - jumper (or dipswitch) selectable.
    I have seen a few such designs, but none provide full pinouts - only pin names (PGC, PGD, etc.)
    Where can I find the pinout for the RJ-12 on the ICD2 and PicKit2?
    Also is there a standard pinout for the 5/10-pin ICSP, or does it vary from programmer to programmer?. I can't seem to find this information.
    Any help would be much appreciated.
    P.S.: If somebody has already done this, please let me know so I don't reinvent the wheel.
  2. #2
    Advanced Member level 5
    Points: 14,575, Level: 29
    blueroomelectronics's Avatar
    Join Date
    Sep 2006
    Toronto, Canada
    Posts
    1,686
    Points
    14,575
    Level
    29
    icd2 pinout
    My Junebug kits ZIF supports most 8 thru 40 pin PICs, although using a socket defeats the whole point of ICD.
    The manuals for the PICkit 2 & ICD2 on Microchips site have the pinout info.
    The 2x5 ICD like my kits use are documented in any of my kit manuals.
    •   Alt29th November 2007, 06:24
      advertising
  3. #3
    Full Member level 3
    Join Date
    Jul 2006
    Posts
    166
    Points
    2,826
    Level
    12
    rj12 connector pinout
    Hello,
    This post serves a dual purpose and perhaps should have been 2 posts, but I digress.
    First, I wish to do away with that ANNOYING RJ-12 on my Potyo 2, and convert it to a 2x5. The cables are much easier to make, and besides, I cannot find any RJ-12 jacks or plugs locally.
    Second, I want to be able to use a ZIF board with a 2x5 connector (I don't always require ICSP - especially on my small projects) on my ICD2 and PicKit2. The idea being that I will have a programmer that can handle virtually ALL PICs - 3v and 5v - and have the option of using ICSP, or a universal ZIF socket.
    Blueroomelectronics,
    Do other PIC programmers use the same 2x5 pinout, or are they different on every programmer?
    •   Alt29th November 2007, 13:45
      advertising
  4. #4
    Join Date
    Sep 2006
    Toronto, Canada
    Posts
    1,686
    Points
    14,575
    Level
    29
    icsp pinout
    It's possible the 2x5 differ but since it's not a Microchip standard anything is possible
    Generally it's
    VPP
    +5
    GND
    PGD
    PGC
    As for the ZIF the pinout is the same for 5 & 3.3V
    It's much different for dsPICs and non-existent for 24 and many 33F (No DIP packages)
    •   Alt29th November 2007, 15:36
      advertising
  5. #5
    Banned
    Points: 22,963, Level: 36
    Join Date
    May 2007
    USA & Canada
    Posts
    437
    Points
    22,963
    Level
    36
    4p4c pinout
    Quote Originally Posted by Computerman29
    Would you please explain what is RJ12?
  6. #6
    Join Date
    Sep 2006
    Toronto, Canada
    Posts
    1,686
    Points
    14,575
    Level
    29
    rj 10 pin
    Quote Originally Posted by funnynypd
    You've used one on your kit...
    The ICD2 has a RJ12 connector, your telephone has a RJ11.
    However, in the interest of simplicity, Midon Design has chosen to refer to the connectors used on our products as RJ11 for a 4 pin device and RJ12 as a 6 pin device.
    http://www.railwaybob.com/Modules/Wi.../RJ12s01a.html
  7. #7
    Full Member level 2
    Points: 1,904, Level: 10
    Join Date
    Sep 2007
    NYC
    Posts
    124
    Points
    1,904
    Level
    10
    pinout rj12
    RJ11 = 4 pins
    RJ12 = 6 pins
    RJ45 = 8 pins
    RJ11 and RJ12 plugs are the same size. RJ45 plug is wider. All 3 can fit and lock into an RJ45 jack.
    •   Alt30th November 2007, 00:03
      advertising
  8. #8
    Full Member level 3
    Join Date
    Jul 2006
    Posts
    166
    Points
    2,826
    Level
    12
    rj12 pinouts
    That pinout should be standardized!! Considering how many different programmers there are, it could get quite confusing. Now I understand why nobody has done this. Thank you for the info.
    Actually there are a few DIP packages of 24F, 24H, and dspic33. Quite powerful little chips too.
    BTW, Any plans to update your Junebug (or design a new device) to program 3V?
  9. #9
    Banned
    Join Date
    May 2007
    USA & Canada
    Posts
    437
    Points
    22,963
    Level
    36
    rj12 pin
    Agree. Good idea.:D
    Added after 11 minutes:
    Quote Originally Posted by xorcise
    RJ11 = 4 pins
    RJ12 = 6 pins
    RJ45 = 8 pins
    Very good. Thanks.
    On some cable supplier web, I saw they called 6p4c as RJ11, and 6p6c as RJ12, I am also confused for 4p4c and 4p2c. I bought a GE cable which claiming suitable for all purpose: telephone, data link, and CAT 5 Ethernet etc. This also confused me.
    Now you make them all clear.
    BTW, the RJ11 and RJ12 can fit to the same socket, the RJ45 plug is wider. I have been used these little devices in my daily life and didn't realise how they are related.
  10. #10
    Junior Member level 1
    Points: 1,567, Level: 9
    Join Date
    Mar 2005
    Posts
    17
    Points
    1,567
    Level
    9
    rj12 pins
    heres the Pinout specs
    gogo
    PS I know this is an old submission, found it on a search and figured this would add to the answer.
