+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Junior Member level 1
    Points: 1,259, Level: 8
    Join Date
    Oct 2007
    Posts
    16
    Points
    1,259
    Level
    8
    What is the difference between RMS and average current?
    what is difference between RMS and average current?
    after simulating, what should i see to measure current consumption?
    till now, i'v checked the average current.
    when can i use RMS value?
    thanks in advance~!:D
    •   Alt14th November 2007, 09:28
      advertising
  2. #2
    Full Member level 6
    Points: 3,633, Level: 14
    Join Date
    Jun 2004
    Sao Paulo - Brasil
    Posts
    332
    Points
    3,633
    Level
    14
    Re: BASIC
    RMS current and voltage are mostly used in alternate current (AC) measurements.
    If you try to calculate the simple average of an AC sinusoidal (or any other periodic) waveform (current or voltage) symetrical from ground, you will get the value zero, as the waveform is composed of positive and negative values, unless you take only one semi cycle (positive or negative alone).
    But AC waveforms of current or voltage can generate power, so using RMS (root mean square) calculation, you can obtain a value relationed to power (V x I) without the cancellation of negative with positive values. The RMS value is the equivalent AC voltage or current that generates the same power of a DC voltage or current value.
    When you squared (to 2nd power) the negative samples/values of the waveform, you turn them into positive values that are added to the positive squared samples. After that you divide by the number of samples and do the root square of the "averaged sum of squares" and obtain the RMS value (for sinusoidal waveform, RMS value is 70% of the peak value, and average value of one semi cycle is 63% of the peak value).
    RMS calculation can be used also in measuring vibration or any other physic event that is variable. Obs. power is not measured in RMS, there is no the unit Wrms, as it does not make sense.
    1 members found this post helpful.
    •   Alt14th November 2007, 11:50
      advertising
  3. #3
    Full Member level 6
    Points: 2,815, Level: 12
    Join Date
    Jun 2004
    Posts
    382
    Points
    2,815
    Level
    12
    BASIC
    which software of your simulation,different software is different
    •   Alt17th November 2007, 14:11
      advertising
  4. #4
    Join Date
    Oct 2007
    Posts
    16
    Points
    1,259
    Level
    8
    BASIC
    really?...I didnt know...
    sim. sftware is hspice or hsim..and
    i usually use awaves or sandwork waveview to see power.
  5. #5
    Member level 2
    Points: 1,825, Level: 9
    Join Date
    Feb 2005
    Posts
    46
    Points
    1,825
    Level
    9
    Re: BASIC
    the average valure is the DC component in the AC signal, whereas the RMS is the effective value that would generate a heat through a resistor like DC.
