System.out
Member level 4
Hello,
Following the schematic below, i have a serial PROM with i can program successfully with iMPACT and a Xilinx S3-400 that i can also program successfully.
The problem is that when i remove the JTAG, and i want to program the FPGA from the serial PROM, INIT_B does not go low, why is it? I can not program the FPGA from the PROM.
I have been thinking on adding a 47K pull-down resistor on the INIT_B line, what do you think? Would that solve my problem?
