fahadkamran
Newbie level 1
Hello, i want someone to write a matlab code that performs:
1- Bit plane slicing on Gray Scale image
2- Take the 8th Bit Plane Image (MSB)
3- Now, combine the first 8 bits of 8th bit plane image and converted it to decimal.
4- Put the decimal value into a new Image.
5- Now, take the next 8 bits of 8th bit plane image and convert it to decimal and put that decimal value again in to that new image on 2nd position and vice versa.
6- Then, take the 7th bit plane image and do the same process by taking the first 8 bits of 7th bit plane and converted it to decimal and put it in the new image.
7- Finally, using all those bit planes and putting the 8 bits into a new image, we will get the original gray scale image.
