modelsim has support for it's own force command, and verilog also has a $force task. You can use either one. Very simple to use.
Thank you for your answer but I can't figure out how to use this commands (I'm a beginner).Can you help me please?
It would help if you explain what you mean by "to inject faults in a DUT". This could have many different meanings.
In fact i want to inject faults in a DUT which means Device Under Test,I created a text file where i have the name of signal that i want to force and the fault type,so now i'm looking for reading a file containing the following : b05_test.dut.n509 0
I'm blocked at the fgets instruction because it doesn't zork this way: scan_faults = $fgets(file_faults , string , data);
Any help please?
