What FPGA logic do constants consume
shaiko
Suppose I have a large set of ~6000 vectors ( 16 bits each ) which I use as coefficients in my design.
There's no address decoding (each set is connected to a specific logic block) and all sets are constant during compile time.
Will these be implemented as simple wires to VCC / GND or there's a chance that the tool will use LUTs / Registers / RAM for some reason ?
If it's appropriate to store the constants in ROM (initialized RAM), you can do that. The tools won't do that "for some reason" rather than your decision.
I don't want to do that.
I need all values to be accessible simultaneously and (obviously) would prefer it consumes no resources other then routing to VCC / GND.
Again,
I have a large array of N vectors and N circuits.
Each vector is connected to a different circuit.
The vectors are all constant during compile time.
Intuitively, I see no reason why these constant vectors shall be implemented by something other than simple wires to either VCC or GND.
And this is exactly what I want...but I'm not 100% sure.
Do you agree that that's what would happen ?
Why not compile the design, and take a look?
Why did you ask about RAM then?
You'll surely get GND/VCC wires in RTL netlist. During synthesis, all possible logic minimizations will be made, pulling the constants into the logic terms. (Unless the logic blocks are locked).
Reactions: shaiko
    shaiko
They just get connected to VCC/GND
Not really, it is more complicated than that. You don't want to have any logic lumped to the ground/vdd wires as they would bounce a lot. You'd typically provide a constant that comes from a special gate called tiecell. There are cells for tie high and tie low. The FPGA vendor might hide that from you, but internally that is how it works.
Reactions: shaiko
    shaiko
Exactly this....
Shown implemented in Vivado like this:
Reactions: shaiko
    shaiko
