beginner_EDA
Full Member level 4
I just want to use XADC for Temperature and Voltage Monitoring purpose and not for any A/D conversion purpose in Kintex.
I found an example design as per
https://www.xilinx.com/support/documentation/user_guides/ug480_7Series_XADC.pdf
As per my understanding MEASURED_TEMP and MEASURED_VCCINT give temperature and voltage respectively.
But didn't understand what should I give input to VAUXP, VAUXN VP, VN input ports? These input ports are only used when using it as A/D conversion purpose or?
and here are the ports:
module ug480 (
input DCLK, // Clock input for DRP
input RESET,
input [3:0] VAUXP, VAUXN, // Auxiliary analog channel inputs
input VP, VN,// Dedicated and Hardwired Analog Input Pair
output reg [15:0] MEASURED_TEMP, MEASURED_VCCINT,
output reg [15:0] MEASURED_VCCAUX, MEASURED_VCCBRAM,
output reg [15:0] MEASURED_AUX0, MEASURED_AUX1,
output reg [15:0] MEASURED_AUX2, MEASURED_AUX3,
output wire [7:0] ALM,
output wire [4:0] CHANNEL,
output wire OT,
output wire EOC,
output wire EOS
and instantiation:
XADC #(// Initializing the XADC Control Registers
.INIT_40(16'h9000),// averaging of 16 selected for external channels
.INIT_41(16'h2ef0),// Continuous Seq Mode, Disable unused ALMs, Enable calibration
.INIT_42(16'h0400),// Set DCLK divides
.INIT_48(16'h4701),// CHSEL1 - enable Temp VCCINT, VCCAUX, VCCBRAM, and calibration
.INIT_49(16'h000f),// CHSEL2 - enable aux analog channels 0 - 3
.INIT_4A(16'h0000),// SEQAVG1 disabled
.INIT_4B(16'h0000),// SEQAVG2 disabled
.INIT_4C(16'h0000),// SEQINMODE0
.INIT_4D(16'h0000),// SEQINMODE1
.INIT_4E(16'h0000),// SEQACQ0
.INIT_4F(16'h0000),// SEQACQ1
.INIT_50(16'hb5ed),// Temp upper alarm trigger 85°C
.INIT_51(16'h5999),// Vccint upper alarm limit 1.05V
.INIT_52(16'hA147),// Vccaux upper alarm limit 1.89V
.INIT_53(16'hdddd),// OT upper alarm limit 125°C - see Thermal Management
.INIT_54(16'ha93a),// Temp lower alarm reset 60°C
.INIT_55(16'h5111),// Vccint lower alarm limit 0.95V
.INIT_56(16'h91Eb),// Vccaux lower alarm limit 1.71V
.INIT_57(16'hae4e),// OT lower alarm reset 70°C - see Thermal Management
.INIT_58(16'h5999),// VCCBRAM upper alarm limit 1.05V
.SIM_MONITOR_FILE("design.txt")// Analog Stimulus file for simulation
XADC_INST (// Connect up instance IO. See UG480 for port descriptions
.CONVST (1'b0),// not used
.CONVSTCLK (1'b0), // not used
.DADDR (daddr),
.DCLK (dclk_bufg),
.DEN (den_reg[0]),
.DI (di_drp),
.DWE (dwe_reg[0]),
.RESET (RESET),
.VAUXN (vauxn_active ),
.VAUXP (vauxp_active ),
.ALM (ALM),
.BUSY (busy),
.CHANNEL(CHANNEL),
.DO (do_drp),
.DRDY (drdy),
.EOC (eoc),
.EOS (eos),
.JTAGBUSY (),// not used
.JTAGLOCKED (),// not used
.JTAGMODIFIED (),// not used
.OT (OT),
.MUXADDR (),// not used
.VP (VP),
.VN (VN)
