Dimensions of 2-d array
nesta
Junior Member level 2
How to find dimensions of a given 2-d array in vhdl? is there any standard attribute to find the dim.
On my PC i do not have a VHDL compiler to make a small example,
so have you tried the array2d'range or (array2d'right or arry2d'left).
regards
JoseMiguel
IIRC, x'length(2) is defined for this. Most of the dimension attributes are overloaded to default to the first dimension, but do take an argument.
most synthesizers usually list support for arrays of arrays. eg "type mytype is array (natural range <>) of std_logic_vector(7 downto 0)". The tools may not like 2-d arrays in some situations, like unconstrained ports or unconstrained inputs to functions.
There is no overloading of any attributes, the number in brackets refers to the nth dimension (starting from 1, annoyingly) for n-d arrays. But for 1-d array a specific dimension is implied as 1.
You example type is a 1-d array, because it only has 1 range specifier in the array declaration.
yes, that is pretty much all I've ever seen recommended from vendors -- the 1d array of 1d arrays where only 1 dimension is not fixed.
