help me with my pic basic code
crabking
Junior Member level 1
help me with my code and my circuit.i made a linear robot,,,it will grip then slide to opposite position then go back to its original position..
the problem is the stepper motor i used did not work properly..it only vibrate
here is the code
here is the code:
clear
ti var byte
c var byte
z var byte
ti=100
trisb=0
gripper open(cw the gripper stepper):
for z=1 to 2
portb=128
pause ti
portb=64
pause ti
portb=32
pause ti
portb=16
pause ti
next z
goto delay
gripper open1(cw the gripper stepper):
for z=1 to 2
portb=128
pause ti
portb=64
pause ti
portb=32
pause ti
portb=16
pause ti
next z
goto delay3
close(reverse gripper stepper):
for z=1 to 2
portb=16
pause ti
portb=32
pause ti
portb=64
pause ti
portb=128
pause ti
next z
goto delay1
close1(reverse gripper stepper):
for z=1 to 3
portb=16
pause ti
portb=32
pause ti
portb=64
pause ti
portb=128
pause ti
next z
goto delay4
delay:
portb=0
pause 2000
goto close
delay1:
portb=0
pause 2000
goto loop
delay2:
portb=0
pause 2000
goto open1
delay3:
portb=0
pause 2000
goto close1
delay4:
portb=0
pause 2000
goto loop1
delay5:
portb=0
pause 2000
goto open
loop(cw the slider):
for c=0 to 11
portb=8
pause ti
portb=4
pause ti
portb=2
pause ti
portb=1
pause ti
next c
pause 2000
goto delay2
loop1(ccw the slider):
for c=0 to 11
portb=1
pause ti
portb=2
pause ti
portb=4
pause ti
portb=8
pause ti
next c
goto delay5
end
here is the circuit:
if you have idea please help..
I have replied the other thread. The usual or best practice is to close one thread and start other one or continue with the same thread. You will not be able to follow 2 threads because your mind has already locked the previous thread and you will never bother to look again.
Re: please help me with my problem about mcu
Here are some useful link to learn.
https://www.edaboard.com/threads/119493/
Read those and do modify according to your requirement you will enjoy it.
Thankyou
it is necessary to define an external clock like xt in the program?
If you intend to use external crystal then you have to. Otherwise I think it internal clock default.
Thankyou
thank you very much...
maybe that is the problem why my project don't run well..
