[SOLVED] ICC Error - Module 'NOR2X0' is not defined. (MWNL-297)
phuang
Junior Member level 1
Hi everyone,
I met an error when I run ICC with the instruction "import_design", shown as following:
icc_shell> import_designs -format verilog -top ChipTop -cel ChipTop_floorplan {./results/compile.v}
Loading db file '/iggroup/home/phuang/Synopsys_Curriculu/low_power_methodology/lpmm_labs/lpmm_lab3/models/saed90nm_typ_ht_pg.db'
Warning: Conflict unit found: MW tech file capacitance unit is pF; Main Library capacitance unit is fF. (IFS-007)
Warning: Conflict unit found: MW tech file resistance unit is kOhm; Main Library resistance unit is MOhm. (IFS-007)
Loading db file '/iggroup/home/phuang/Synopsys_Curriculu/low_power_methodology/lpmm_labs/lpmm_lab3/models/saed90nm_min_pg.db'
Loading db file '/iggroup/home/phuang/Synopsys_Curriculu/low_power_methodology/lpmm_labs/lpmm_lab3/models/saed90nm_max_pg.db'
Loading db file '/CAD/Synopsys/ICC_vC-2009.06-SP4/libraries/syn/gtech.db'
Loading db file '/CAD/Synopsys/ICC_vC-2009.06-SP4/libraries/syn/standard.sldb'
***** Verilog HDL translation! *****
***** Start Pass 1 *****
Begin loading DB for bus info.
End of loading DB for bus info.Elapsed = 0:00:00, CPU = 0:00:00
Warning: All isolation_upf and retention_upf pragmas are ignored. (VER-282)
***** Pass 1 Complete *****
Elapsed = 0:00:01, CPU = 0:00:00
***** Start Pass 2 *****
Error: Module 'NOR2X0' is not defined. (MWNL-297)
hdlCleanupDBLibrary:
Error: Verilog parser cannot parse the /iggroup/home/phuang/Synopsys_Curriculu/low_power_methodology/lpmm_labs/lpmm_lab3/results/compile.v source file. (MWNL-047)
No such file or directory
Error: Current design is not defined. (UID-4)
icc_shell>
Following the the manual of MWNL-297, I checked my netlist file and the FRAM reference library, both of them contain the module 'NOR2X0' .
So how to deal with the problem? I am puzzled.:-x
looking forward to your advice. Thanks a lot!
  • scripts.txt
Hey, were you able to solve the issue?? I'm facing the same problem...
I used -allow_undefined_module as suggested by the error message.
So, its not giving any errors now... but I don't see the FRAM being used in my top level module.
Thanks.
---------- Post added at 05:38 ---------- Previous post was at 04:18 ----------
I should rephrase the question.... I have created the FRAM and ILM views for the module (to be integrated in the 'top' level).
I don't know how to integrate the FRAM/ILM views while importing the top_level module's verilog file.
Currently, I am including the path of the module_LIB as a reference library - but yet, while reading the module instantiation in the top level netlist, it throws an error {module not found}. This error disappears when I use -allow_undefined_module with read_verilog.
Reactions: phuang
    phuang
Hi everyone,
Are you giving milkyway reference library(mw_reference_library) properly? I had the same issue which I fixed by giving the right reference library.
Reactions: phuang
    phuang
Thanks.
Hi surpriya.7,
Thanks for your attention and advice. but the -allow_undefined_module just shade the error from modules that not found.
I solved the problem by giving the right milkyway reference library(mw_reference_library), since the original FRAM format is like AND2X1_1, while the right should be AND2X1:1, when I gave the right one, the proble was fixed.
Thank you!
Cheers,
phuang
---------- Post added at 16:48 ---------- Previous post was at 16:46 ----------
Hi dianin,
YOU ARE RIGHT!
I solved the problem today by the same way as what you did, --- give the right milkyway reference library!
Best,
phuang
