dragonfury
Member level 4
My Question is what are Digitally Assisted Analog Circuits and why do we need them? & What are the Prerequisites for working in this field?
Ok I would like to ask one more question .Which field has more better job opportunities? Analog and mixed signal IC design or RF circuit level designing?
My understanding is that digital assisted analog is a little different from mixed-signal design. Or you may say the former is an extension of the latter. Usually a mixed-signal design just means you put digital and analog functions on the same chip. But in a digital assisted analog design, the digital part is actually helping the analog part to work properly. One example is digital calibration. In advanced technologies, the process variation is a big problem. Of course you can always use large transistors and over design the circuits, but that will incur prohibitive power and area overhead. So one thing you may do is to use some digital circuits to monitor the performance of the analog part and correct any non-idealities. Data converters, oscillators, references can all benefit from this technique.
