well in this book my david peterson the instruction memory and data memory are separate for single cycle datapath
instruction memory stores the instuctions that are being executed while data memory is used to store values and addresses
i need to know the operation of the two memory. how to use jump command ? and i am from universiti tunku abdul rahman.i need to know more details about this two memory how to work in this processor .thanks a lot !
for this u have to see the assembly command set for this processor
its on 1st 2 pages of the book that ur reading
pcspim is the software that ull need
chk out sample codes on the internet
click helped me if u think i really helped u
Added after 3 minutes:
more over plz tel me if u have worked on serial communication or at commands on a gsm modem thanx
