Unconnected output port in Design Vision
richeek
Newbie level 5
College Station Texas
Hi
I have written a verilog code for a processor. It has a program counter. When I am running check design on my top module, I get an unconnected port in PC.
Here is the verilog code of PC:
`timescale 1ns / 1ps
module PC(din, dout, load, countEn, rst);
input[7:0] din;
input load, countEn, rst;
output[7:0] dout;
reg[7:0] dout;
always @(posedge countEn)
begin
if(rst)
dout <= 0;
else if(load)
dout <= din;
else
dout <= dout + 1;
end
endmodule
I descended in the hierarchy and there is a cell B_1 in PC that is unconnected.
The problem is that I am unable to debug why this cell is getting generated at the first place? What is redundant in my code? I am attaching the JPEG image of the generated design schematic of PC.
Any help would be appreciated.
Thanks.
Richeek
you fail to initialise the 'reg' array or its variable's
input[7:0] din;
output[7:0] dout;
reg[7:0] dout;
you must initialise the reg as an 8 element array
i think the syntax is
to actual declare the structure you define
here is a simple bridge code from 8 bit bi dir 16 bit data to 16 bit word bus
you actual have to declare the register structure
or its not valid and the compiler etc will throw one
here is a valid code block from a bridge code
to allow atari acsi 8 bit overword transfer to 16bit word syncro
to further allow coms with spi
youll find the full project on jookies site here
`timescale 10ns/1ns
module main(aDATA,bDATA,ACK,DRQ,INT,CS,A1,GotCmd,Do,Done,PIOnDMA,RnW, CLK, ClrCmd);
inout [7:0] aDATA;
input ACK;
output DRQ;
output INT;
input CS;
input A1;
inout [7:0] bDATA;
input Do;
output Done;
input PIOnDMA;
input RnW;
output GotCmd;
input ClrCmd;
input CLK;
>>>>>>>>elements of reg array these are initialisers also so set inital val
reg [7:0] rDATA;
reg mDo = 0;
reg rINT = 1;
reg rDRQ = 1;
reg rDone = 0;
reg rGotCmd = 0;
reg Hold = 0;
reg prevCS, prevACK;
>>> ie reg has 8 elements declared before posedge detect begin cycle
>>> mDo[0] rINT[1] rDRQ[2] rDONE[3] rGotCmd[4] Hold[5] prevCS[6] prevACK[7]
= 8 elements filled logicaly 0-7 as elements or array NODE'S
then you can compare the control register like as byte or nibble
ie 4 or 8 bit control struct
as registers are control structures ie msb 00000110 lsb
as is before begin routine change of the 'control' register
always @ (posedge CLK)
begin
if(!mDo && Do) // posedge Do
begin
if(PIOnDMA) // PIO
begin
rINT = 0; // the INT to L
rDRQ = 1; // restore the DRQ
end else // DMA
begin
rDRQ = 0; // the DRQ to L
rINT = 1; // restore the INT
end
if(RnW)
begin
rDATA <= bDATA;
end
rDone <= 0;
mDo <= Do;
end
if(mDo && !Do) // negedge Do
begin
rDone <= 0;
mDo <= Do;
end
if(ClrCmd) // clear Done
begin
rDone <= 0;
rGotCmd <= 0;
Hold = 0;
end
if((prevCS && CS) || (prevACK && ACK)) // if signal is H
begin
Hold = 0;
end
if((!prevCS && CS) || (!prevACK && ACK)) // if raising edge
begin
Hold = 1;
end
// if(!CS || !ACK) // if I should latch the data
// if(!CS || (!prevACK && !ACK)) // if I should latch the data
if((!prevCS && !CS) || (!prevACK && !ACK)) // if I should latch the data
begin
if(!RnW && !rDone) // write?
begin
rDATA <= aDATA; // from ST to AVR
end
Hold = 1;
if(!CS)
begin
rINT = 1;
end
if(!ACK)
begin
rDRQ = 1;
end
if(!CS && !A1) // if command was received
begin
rGotCmd <= 1;
end
rDone <= 1;
end
prevCS <= CS;
prevACK <= ACK;
end
assign bDATA = (rDone && !RnW) ? rDATA : 8'bz;
assign aDATA = ((!CS || !ACK || Hold) && RnW) ? rDATA : 8'bz;
assign INT = rINT ? 1'bz : 0;
assign DRQ = rDRQ ? 1'bz : 0;
// assign INT = rINT;
// assign DRQ = rDRQ;
assign Done = rDone;
assign GotCmd = rGotCmd;
endmodule
Added after 26 minutes:
input[7:0] din;
output[7:0] dout;
reg[7:0] dout;
reg d0,d1,d2,d3,d4,d5,d6,d7;
will work with no compiler error
Thans for the reply VSMVDD.
I still have some doubts.
Why do I need to initialize the dout array? The cell B_1(see figure) that is left dangling how does that is related to initialization?
VSMVDD said:
you fail to initialize the 'reg' array or its variable's
input[7:0] din;
output[7:0] dout;
reg[7:0] dout;
`timescale 10ns/1ns
inout [7:0] aDATA;
input ACK;
output DRQ;
output INT;
input CS;
input A1;
inout [7:0] bDATA;
input Do;
output Done;
input PIOnDMA;
input RnW;
output GotCmd;
input ClrCmd;
input CLK;
reg [7:0] rDATA;
reg mDo = 0;
reg rINT = 1;
reg rDRQ = 1;
reg rDone = 0;
reg rGotCmd = 0;
reg Hold = 0;
begin
begin
if(PIOnDMA) // PIO
begin
end else // DMA
begin
end
if(RnW)
begin
rDATA <= bDATA;
end
rDone <= 0;
mDo <= Do;
end
begin
rDone <= 0;
mDo <= Do;
end
begin
rDone <= 0;
rGotCmd <= 0;
Hold = 0;
end
begin
Hold = 0;
end
begin
Hold = 1;
end
begin
begin
end
Hold = 1;
if(!CS)
begin
rINT = 1;
end
if(!ACK)
begin
rDRQ = 1;
end
begin
rGotCmd <= 1;
end
rDone <= 1;
end
prevCS <= CS;
prevACK <= ACK;
end
endmodule
input[7:0] din;
output[7:0] dout;
reg[7:0] dout;
Hi richeek,
I guess you have this warning after elaboration not after compile. If yes just ignore it.
I also have this warnings in my designs very often. But only after elaboration phase. After compilation their are disappearing.
I think this is DC bug.
Bests,
Tiksan
http://syswip.com/
I got it after I did check design. Also B_1 is actually NOT(reset OR load)
Can anyone explain how does code is getting synthesized like this?
Richeek
When are you running check design after compilation or before?
    richeek
Yeah, you were right. It seems to be a bug in DC. Now after compilation the unconnected port is gone. Thank you very much.
