medra
Full Member level 2
viterbi in simulink
Dear all
Please reply if you have any related information to any question
I have a wimax simulink model file . if using reed solomon decoder , the model can easily be downloaded on DSP with no problems. But if we used convolutional encoder and corresponding viterbi decoder ,the downloading fails.
I started to examine the conversion of the convolutional m-file and viterbi -m file to the c language by using emlc command. I found problems but managed to solve them except a strange problem. the viterbi alogorithm calls a function called vit.mexw32 which is c code optimized to work on matlab platform, this function makes error while converting the viterbi.m to c ( evenif it is a C code !!!!!!!!!). what is the solution to this problem???
if the conversion is successfull on m. file ,will it be succesful for simulink model as well??
could I edit the simulink viterbi model???
is the embedded matlab guarenteed to be converted to c files and easily downloaded on DSP?? ( that is , if I managed to make an embedded matlab simulink block which has the same function as viterbi, I will pass the problem)
please give me any related information to the topic, may be you have an altenative solution to the problem.
Dear all
