PIC Programmer for Non-serial port PC
nomad13
Full Member level 3
rs232 non-serial port
Yesterday I've done a PIC programmer that I found on the net.
It is based on KIT 149bc. I connect it to my laptop that has no serial port. Run the software and it works.
The original diagram was modified. I remove the FTDI chip because I'm planning to use a USB to RS232 converter cable that I have. The pcb I made was single sided.
I've tried many serial programmer but this is the only one that works with a USB to RS232 converter cable.
seriel pic programmer
nomad13,
hi, does this work on pic16f877a or other 40 pin PIC's?
serial port pic programmer for laptop
Actually the first chip I tried was a 16f877a.
Reactions: fahdjo
    fahdjo
Here are the board and 3d view layout.
PM me for more info>
:D
You should post the firmware for the 16F84A, although like my Inchworm+ you still need to get the chip programmed.
Has anyone got PCB layout files & schematics available for one of these that they can share?
Cheers.
Roland.
thanks nice one!I could use it!
Hi.. nomad13 ..
Can you place the firmware for P16F84
Rgds
..jorank..
anuruddha.mrt said:
nice circuit.can u send firmware? thankx!
You may download DIY pack of similar programmer including circuits, description and the firmwares from the given link below
https://www.kitsrus.com/pdf/k149d_intro.pdf
OR
You may also consider building a PicKit2 clone which directly communicates with the USB port of the PC where no drivers are required as the programmer is Compatible with MPLAB. Find more more info at these below mentioned links.
Cheers
