References on types and structures of UWB antennas
adel_48
Full Member level 6
UWB Antenna
Dear All,
Does anybody have good resources about types and structures of UWB antennas?
BR
Adel_48
Re: UWB Antenna
UWB needs the antennas have broad BW .
So it can use monopole to make it easily.
An introduction for your reference.
    adel_48
Re: UWB Antenna
Hey
this is a hot topic right now. I think most commonly used antennas are vivaldi and ovals dipoles. I think oval dipoles are nice because they cause very less dispersion to the pulse you want to transmit and their pattern is dipole-like over the bandwidth.
Cheers
UWB Antenna
thank you very much tomcat_x and arunrock, I was also looking for 3D antenna structures such as the tapered dielectric rod antenna. Do you have any resources about it or other 3D structures?
Re: UWB Antenna
You can have a look in "Antenna Theory" by Balanis.
You will find information about spiral antennas, which are frequency independent.
Hope this match your request !
Re: UWB Antenna
Dear All,
It is a very nice presentation by myself. It is helpful.
Best regards,
Mohamed
Reactions: per_lube
    adel_48
    per_lube
Re: UWB Antenna
hi yes , frequency independant antennas are uwb antennas , but for the "modern "UWB radio system which occupy the band from 3.1-10.6GHz, the UWB antennas must have low dispersion as excited by Gaussian impluse , generally speaking , frequency independant antennas are not the good candidaters. Regarding modern UWB antennas , please look at the great book of Dr. Schantz's "The art and science of Ultra-Wideband Antennas" or just search IEEE by author : schantz , there are many papers .
hope this helps
kaka
Re: UWB Antenna
Hi: There is another book on small antennas and UWB antennas. It is by Dr. Zhining Chen and it was just published by Wiley. Dr. Chen did much work on UWB antennas. Please check it.
Re: UWB Antenna
UWB Theory and Applications
Edited by
Ian Oppermann, Matti Hamala inen and Jari Iinatti
All of CWC, University of Oula, Finland
Copyright  2004 John Wiley & Sons Ltd,
Re: UWB Antenna
Have a look at this nice paper: Characterization of ultrawideband antennas using transfer functions
UWB Antenna
Hey
this is a hot topic right really. I think most commonly used antennas are planar patch Antenna and laoding dipole. I think loading dipoles are nice because they cause very less dispersion to the pulse you want to transmit and their pattern is dipole-like over the bandwidth
UWB Antenna
does anyone know about uwb spiral antenna design or can u tell me references to search? thanks
Re: UWB Antenna
Hi:
I tried an antenna example with 4 elliptical shapes and the result is excellent. I could easily achieve S(1,1) < - 10 dB from 3 to 11 GHz. The size is just regular shape. The example is documented in the IE3D manual as an example using the FastEM Design Kit for real-time EM synthesis. Interested users can check it (www.zeland.com). Regards.
Re: UWB Antenna
Take a look at IEEE.
