oddbudman
Member level 5
(I asked this on the freescale forum, but i thought i'd try here too )
Hey there fellow freaks, I'm new to the world of HC08, so I apologise in advance if i've made a dumb mistake.
I'm trying to develop a custom DALI Slave application.
I have the above hardware, but I am unable to connect to the slave board in monitor mode.
I have replaced the chip (MC68HC908KX8) with a new one, and was able to connect to the slave board using monitor mode, but once I flashed the chip with the dali slave applicaiton code I was unable to reconnect to the slave board using the monitor mode.
Does anyone have any idea what could be causing this problem? Is there a config register I need to configure? or a vector to the monitor mode that needs configuring?
I'm using the example s19 software file that you can download from the Freescale website (just do a search for DALI to find it)
From memory this problem only really started to happen when we changed memory location FF7E from FF to FE, but I'm not 100% sure on this
Quote from datasheet:
Any help on getting into monitor mode would be greatly appreciated.
thanks in advance,
oddbudman
PS doing a search for 'DALI' on the freescale website should list all the data sheets and software I have been working off.
Software/Slave/Executable/Slave.s19Downloadable code for the DALI reference design
Fromage 61 -Digitally Addressable Lighting Interface (DALI) Unit Using the MC68HC908KX8 Designer...After the code is replaced the memory position FF7E (FLASH
Block Protect Register) has to be set to FE.
thanks in advance,
oddbudman
