Arduino CTC mode output not as expected
fm101
Member level 5
I have the following CTC mode arduino code to generate 100khz square wave at pin 6.
C++:
void setup () {
  //Pin 6 (OC0A) is output
  pinMode(6, OUTPUT);
   // Load 79 to generate 100 kHz sq.wave
  OCR0A = 79;
   // Toggle OC0A on compare match, WGM 2 (CTC mode)
  TCCR0A = (1 << COM0A0) | (1 << WGM01);
  // Start the timer, no prescalar
  TCCR0B = (1 << CS00);
void loop() {
But the oscilloscope shows peaked square wave at frequency 7.99MHz and the amplitude is just 765.44mV as shown below.
Using delay and microseconds function I was able to generate expected square wave with frequency. But with the above CTC mode code I am not able to generate expected square wave. What could be the problem?
What hardware do you use? (Microcontroller, module ...)
What's the system clock frequency?
Try setting TCCR0A and TCCR0B to zero so you have everything at 0 to begin with.
void setup () {
  pinMode(6, OUTPUT);
TCCR0B = 0;   // write 0 to timer 0 control registers
 TCCR0A = 0;
  OCR0A = 79;
void loop() {
Sorry for late reply, I was out. I am using Arduino Uno which is board based on ATmega328p. Clock frequency is 16MHz. Output frequency desired is 100KHz. Using Timer 0 in CTC mode.
void setup () {
  pinMode(6, OUTPUT);
 TCCR0A = 0;
  OCR0A = 79;
void loop() {
Yes with the initialization I get closer waveform which is at 34.3KHz but still not getting the calculated 100KHz and the amplitude is just around 590mV.
Any further advice? could this be due to the DSO because this is new one?
Before my previous post, I ran your code on my Arduino and received the same 8 Mhz as you experienced. Starting with TCCR0A and TCCR0B zeroed, your code ran with the correct 100khz on pin 6. I suspect that the bootloader may cause the registers to be non zero to start with.
The low voltage you are experiencing and incorrect frequency, Is a separate issue. My arduino, is showing a 10 microsecond waveform with an amplitude of 4.8 volts at pin 6 on the scope.
Check for loading of the signal, probe settings (10x or 1x), and double check scope settings.
Maybe measure frequency with a mutimeter if you have one that will measure the expected signal.
    fm101
Thank you for testing and confirmation.
I now got the correct frequency and amplitude. The attenuation probe setting led to amplitude misread and changes in the OCR value led to the frequency mistake.
