2 GHz Frequency Generation
mickey123
Member level 5
Is it possible to generate 2 GHz frequency as an input to an antenna in a simple college laboratory setup ? What are the other options ?
Thanks in advance :)
Yes. Other options are no or maybe.
Thank you very much for your reply:)
If I use such an IC should I fabricate it on a separate board?
Should I attach any extra components as mentioned in the datasheet?
How do I connect it with an antenna?
How can I control and measure the input power given to the IC ?
Making a 2GHz oscillator is not such complicated.
In the schematic attached you can use any other high frequency BJT transistors from NXP or Infineon.
Thank you so much for the reply :)
Any help regarding the previous post in the same thread ?
https://synergymwave.com/products/saw-oscillators/datasheet/HFSO2000-5.pdf
You would have to solder this to a PC board, and the antenna would also attach to the board.
But the board is non critical...just so long as the backside is a ground plane. You could cut the board with an exacto knife, and peal away the unwanted copper with a soldering iron and some tweezers.
