How to use power switch
strahd_von_zarovich
Hi, I am trying to figure out how to use this power switch :
Which connections should be made to illuminate led only if i turn the switch on and of course provides electricity to my load.
Each device has a datasheet.
Find out it'smanufacturer and type name, then download the datasheet and read it.
So it has 9 terminals.
Power entry a the bottom: 3 terminals marked with "L", "N", and Eerth ground.
Fuse at the center: 2 terminals
Switch at the top: 4 terminals of an DPST switch. One pole left, one pole right.
Where do you have difficulties?
Better to by inbuilt LED switch as below link
https://www.digikey.com/product-search/en?mpart=4304.6071&vendor=486
Insert a fuse (based on the current rating) solder the output wire (1 line wire , 1 neutral wire , 1 earth ground wire) earth wire probably attached to chassis.
Keep in mind that line terminal will go to fuse then switch and neutral terminal directly go to switch (you can use switch outputs line and neutral for your application)
Please take a multi meter and conform if you have further doupt
Thanks everybody for help.
It is a simple series circuit then. High voltage scares me a little. Sorry for wasting your time.
