marce
- Joined
- Feb 23, 2010
- Messages
- 2,079
- Helped
- 627
- Reputation
- 1,256
- Reaction score
- 633
- Trophy points
- 1,393
- Location
- UNITED KINGDOM
- Activity points
- 14,401
Sorry but I totally disagree, the best layouts are done by dedicated PCB layout engineers, why do so many high reliability, medical, military companies still use dedicated layout engineers, the days of the do it all engineer are long gone, now you have engineering teams with specialist in each area, electronics, software, DSP, layout etc...I tend to disagree, its better if the hardware designer does the pcb layout aswell, especially the first prototype, when multiple changes are needed...in my last job, I whizzed a pcb off with eagle and every time I needed to change something (due to spec change etc), I was quickly able to do so...I didn't have to keep going up and hassling a pcb layout guy....because I was that guy.
Also most complex packages are pretty easy to use for simple PCB's, in fact with any CAD or EDA system the setting up, be it for simple or complex projects is critical if you want the best quality results.
Some of the worse SMPS layouts I have seen have been done by engineers, and this is one area I know quite intimately as I am often called in to re-do these layout that have failed in some way, be it EMC or some other problems, and do numerous SMPS layouts for critical equipement and where noise and EMC emissions are not an option.regarding pcb layout electrical skills with simple smps's, an awful lot involves making sure pulse current loops, or loops with high rise time signals in them are made as narrow as possible.....small as possible loop area....and obviously things like not routing the ground in a power switch loop of an smps round the whole board, and through the control circuitry etc.
How many years have you been doing this, cos 20 companies seems a lot unless you are a contractor.
