Geoffrey_85
Newbie level 6
Hi there:
I am trying to figure out which is the best way of simulating a CBCPW (conductor backed CPW) in Mometum ADS 2009. I am using a GaAs substrate (E_r=12.9, loss tg=0.006 and h=100um) as dielectric. I am trying to simulate high frequency structures (up to 300GHz).
I have tried simulating various ways:
1. defining slot structure and simulating the structure using 4 coplanar ports (the ones on the same side being associated to one other and with reversed polarity-just as indicated by ADS documantation).
2. defining strip structure, with 2 top GND planes and the central conducting line in between. As for the ports in this case I have tried both: single for the central conducting line and ground reference for the ports connected at the edges of the two top GND planes, as well as internal for the central conducting line and ground refference for the two top GND planes, when thses ports are moved a bit inside the GND plane - done according to "Methods of Simulating Structures on Electrically Thick Substrates" help file on edocs agilent webpage.
-for both methods the bottom GND is considered infinite
Now all simulation methods give distinct results. The better one is the one which is slot based model, but the problemwith that is that it does not account for losses in the conductor and it considers the top GND planes infinite. The strip based models give worse results, with increased radiation.
I know that when using CBCPW it is recommended using vias to connect top with bottom GND, this is the next step, but previously I would like to know which of the method is closer to a practical measurement? If anyone has any experinece with properly simulating CBCPW structures in Momentum I would certainly need his feedback on the problem.
Thanks a lot!
Thanks a lot!
